Hi there, I'm new and in need of help!
I've got a Baxi Solo 40 HE boiler (non-combi) and I've been having trouble with my CH/HW. I had an old Landis & Gyr mid-position valve that had jammed, which I've now replaced with an equivalent Danfoss HSA3. I also replaced the ancient Siemens programmer with a new Siemens (Wickes) RWB9 and re-wired the junction box at the same time as the wiring was a mess.
Most of the time, the system works perfectly. However, occasionally the CH will get 'stuck' on, even when the programmer is not calling for CH and/or the room stat is not calling for heat and the system gets stupidly hot. I turn the whole system off at the fuse and it goes back to normal.
I've triple checked the wiring and the terminations, and they're all fine.
I've had my multimeter on the various terminals and the only thing I can find out of the ordinary is when the HW OFF terminal is live (showing 240V), the HW ON and CH ON terminals seem to have 50V on them. I am aware of induced current in adjacent wiring, but this seems excessive?
I've been fiddling with it all day and I'm probably blind to the problem from looking too hard, so any input would be greatly appreciated.
Thanks for your time,
Ed
P.S. I'm a Mechanical Building Services Consultant, so you can be as technical as you like!
P.P.S. If anyone needs any advice on building regs, rad-sizing, Part-L Compliance problems etc. feel free to PM me
Ed
