Hi Guys
I am at the stage of fitting fire doors to all rooms opening onto landing and hallway as part of my loft conversion.
I am looking at these doors:
http://www.howdens.com/pdf/product/1232.pdf
However, my existing openings are narrower than the doors. The doors are 762mm, and can be trimmed down by 8mm (4 each side). But my openings are 742mm, 750mm, 740mm.
The reason for these doors is they have the intumecent strip built in already, are 35mm deep do can use existing linings.
However the width is an issue. Can anyone suggest a way forward here? will I have to get doors without the strip, and then router in a slot?
I can use doors deeper than 35mm as the door stops can be moved back on the casings.
Tatsky
Tatsky
