- Joined
- 10 May 2025
- Messages
- 2
- Reaction score
- 0
- Country
Good evening,
I’ve recently installed a Premier Elite 64-W system with a wired 16Ω internal speaker connected to the panel, along with a wired keypad.
I’m struggling to correctly configure the volume levels for when I full set the system.
Initially, the entry/exit tone was too loud via the internal speaker. I reduced the 'Advisory Volume' in Global Options, which solved that problem.
However, after lowering the 'Advisory Volume', I noticed that when the alarm activates, the internal speaker is too quiet to hear the alarm tone.
I then adjusted the 'Panel Volume' setting in Engineer Utils on the keypad, which fixed the alarm volume - but it also seems to override the 'Advisory Volume' setting as well, making my Entry/Exit extremely loud again.
What I’m trying to achieve:
Thank you in advance.
- Entry/Exit tones at a lower volume (e.g. volume 3 - or ideally only through the keypad)
- Alarm activations at a high/max volume
