I have two bedrooms divided by a 3m long dark grey crumbly block wall built directly on the floorboards which I plan to remove - no wall beneath.
The property was built in the early 60's and the roof construction does not have trusses - the rafters rest on the outer walls supported by 2 purlins and 3x2 joists span the 6m length between the outer walls. The wall I would like to remove is central to the 6m span.
Am I correct in assuming this wall is not actually supporting the rafters and tiles but does supply a level of support to the joists in the loft and therefore I should replace the wall with some support in the form of 2 off 6x2 wood beams bolted together? The loft is used for general storage - nothing heavy, no water tanks.
Any advice would be appreciated
