Hi,my bathroom need a bit retiling. I knocked some loose tiles off. There are two coats on the brick wall. One is cement base with thickness around 10mm. The other pale red-Brown coat on the surface is much thinner with thickness around 1-2 mm. The thinner coat is loose.
I was wondering how can I redo the thinner surface Is this a
Plaster surface? Is it OK for me directly tiling on the cement coat without redo the thinner surface?
