IP protecting CU
10 Jul 2006
Cleveland
A cable goes into the top of my CU and has the full knockout removed, leaving quite a large hole. What can i buy to put over/in hole to make it IP4 protected, becaused dosn't regs require that?
- Run the cable in mini-trunking large enough to conceal the gaps.
- Fill the hole with ordinary silicon sealant.
- Cut a neat cable-sized hole in a piece of matching plastic sheet and stick it to the CU in place around the cable.
