Evening all
I need some answers (and quick please!).
1. I have a lighting circuit with 4 X low voltage down lighters.
Q- Do I have to remove trannys from the circuit as well as lamps? I've taken readings for N- CPC and P-CPC which are acceptable but P-N is completely diffent!? Help!
2. In the same room I have installed a new ceiling. I have connected to the old ceiling rose and daisy-chained off with 1.5T&E to each fitting. The CPC is connected all the way through back to the rose but is not connected to the trannys.
Question - How do I perform an Earth Loop Impedance test on this circuit?
3. In the bathroom all the pipework is plastic including heating. I have 4 LV down lighters and one 1 shaver socket. There is also a metal bath and a plumbed towel warmer. i have wired it to a 6amp MCB and connected it to the RCD side of the CU. Q - Do I still need supplementary bonding.
I'm using this job as one of my assessment jobs for the NICEIC Domestic Installer Scheme.
Thanks guys in anticipation
Brian
Brian
