Iron to plastic pipes
4 May 2007
Oxford
How do I connect an old iron mains supply pipe to a new plastic(?) pipe, which then needs an internal stop-tap before connecting to copper pipe!?
(my supply pipe has a leak right outside my house and needs re-routing into a new extension anyway),
Thanks,
Steve
I have used compression fittings on iron pipe on many occasions but it depends on the size you have.
22mm might do the trick :?:
If the mains is leaking it's safe bet the pipe has had it's day, I think you should replace as much as posible preferably back to the stopcock.
