irrigation pump
18 May 2006
Tyrone
need to run a cable 200metres to the river for an irrigation pump, the pump is 240v will not be swa will be buried 600mm deep in conduit.
What size cable do you think i need?
I have a feeling there is a rather vital piece of information missing here...
mead said:
if you havent got an answer dont post
If thats what you want, then I may as well have the mods lock the post now, no one is going to be able to give you an answer with with the incomplete information you have provided.
what adam is saying is. what will the pump be using energy wise. ie, what wattage is the motor. you cant work out the cable size without this VITAL bit of info.
what sort of conduit are you using? it should be metal conduit. Do you have the correct tools for making off the ends of metal conduit?
where does it state to use metal conduit in the regs crafty?
i know the ESQCR says that all burried live conductors (other than at joints) must be surrounded by earthed metal, I belive 7671 has a similar clause though i can't give an exact reference.
so either the cable needs to have such a layer built in (SWA,split con,MICC etc) or it needs to be in metal conduit.
