Is 2.5mm cable enough for a 3kW device?
11 Jun 2009
Oxfordshire
My electrician, during the house rewiring, has made provision for my immersion elements with 2.5mm cable. However, the cylinder is a megaflo and both immersion heaters (an economy 7 setup) are rated 3kW.
In the case of both daytime and nighttime supply there shouldn't be anything else on the circuit/cable supplying the element that will increase the load. Do I need to replace the 2.5mm cable with 4mm cable, or will the 2.5mm be sufficient?
All feedback is appreciated.
Cheers
There should be two separate feeds though one for each immersion.
From your post, one would be from the off peak and one on the normal (24hr) supply.
Yes, that's right, there will be two separate feeds, one for each immersion (one from the off-peak supply and one from the normal supply). So two 2.5mm cables, one for each element.
Thanks for all the replies, they've put my mind at rest.
