From what I can see, compliance with section 702 does not result in non compliance with any other part of the regulations, so treating a hot tub as if it’s a small swimming pool seems to be the most sensible approach.
Exactly. As I just wrote....From what I can see, compliance with section 702 does not result in non compliance with any other part of the regulations, so treating a hot tub as if it’s a small swimming pool seems to be the most sensible approach.
.... The suggestion that, because hot tubs are not explicitly mentioned as being within the scope of 702 means that the requirements of 702 do not apply is, I would have thought, the 'most dangerous' of the possible assumptions. In the absence of clarity in the regs, is not the (pragmatically) 'safe'/'conservative' approach to assume that 702 does apply to hot tubs, even though it does not say that explicitly?
I would say that it is impossible for an electrician "to be clear" about that, given that the regulations themselves are not "clear" - so, as I've said, I think that, unsatisfactory though it is, one has to use one's own judgement (whether called 'common sense', 'the spirit of the regs' or whatever').
'Guidance' from sources other than the regs themselves (even if produced by the authors of the regs) does not really help to tell one what is intended by the (unclear) regulations.
Kind Regards, John
It does say that, but such regulations can rarely be comprehensive, particularly in the absence of definitions. A quick search finds things described as "pools", "plunge pools", "family pools", "exercise pools" "Swim Spas" etc. - do you not believe that any of them qualify as "swimming pools"?The wording of section 702.11 is quite clear, it does not refer to hot tubs, and actually excludes them because the wording says "in particular" and then refers to swimming pools etc.
No amount of guidance, even if it comes from one of the co-authors of the regulations, can alter what the regulations currently 'actually say'.Hence the need for the IET guidance.
Quite so. As I keep saying, I think any attempt at distinction is not only futile but is also potentially detrimental in terms of safety. I personally feel that anything full of water that I can 'dip my foot into' should (if there is any electricity in the vicinity) be subject to the same safety requirements/standards as a massive structure that everyone would agree was a 'swimming pool'.Just to throw another spanner into the conundrum. Although people don't class hot tubs as swimming pools, my granddaughter learnt to swim when she was 2 As she was a 10 week prem baby she was still very small for her age at that time so she would take 5 or 6 breast strokes to swim from one side of the hot tub to the other. In her eyes it was a swimming pool and she used to ask if she could go in the swimming pool.
NIC say lots of things!NIC say not. Recent article in Connections mag.
Nor do I think that "in particular" (or "particularly") necessarily implies a comprehensive/'exclusive' list. If I said that "I like eating meat, in particular beef", I don't think that would mean that types of meat other than beef were excluded from the list of meats I 'liked eating', would it?
If they were asked and gave an answer, I can only think of two possibilities. Firstly, they could confirm that the regulations, as worded (and as literally interpreted by you) corresponded with their intention (even if I personally would find that hard to understand). Secondly, they could indicate that they had intended to (but hadn't) make the regulations applicable to any structure containing water intended for people to partially immersed themselves in. However, that admission of different 'intention' would not change what the regulations 'actually say' (hence what one has to do, or not, to comply with the regulations 'ass they are') - they could only alter the situation by amending the regulation.
I continue to not really understand what is the perceived problem. As RF and I have said, assuming that 702 applies to hot tubs would not result in non-compliance with any other regulations - so, particularly if (as I do) one believes that application of the regs to hot tubs corresponds with 'common sense', then why not just make that ('conservative', 'safer') assumption - rather than to take the ('less safe') view that the additional safety measures required by 702 do not apply to 'a pool' which happens to be called a 'hot tub'?
Kind Regards, John
As I've said, even though they are a co-author of BS7671, nothing the IET write in a 'guidance' document can change what actually is written in BS7671. If what they say in GN7 differs from what BS7671 says, then if they want things to be as stated in that guidance document, they would have to amend BS7671.I thought that IET made special guidance note 7 just for this kind of thing? ... Bargain at £32
That may be 'clear' to you, but it certainly isn't to me.The term "particular" is clearly used to mean "specifically", and therefore excludes other types of basin or pool not mentioned.
As I've said and implied repeatedly, I certainly hope so (but will not be holding my breath!) - and, given what I wrote before do you think they will also 'extend' the reg to include "plunge pools", "family pools", "exercise pools" etc. etc?That is why the IET considered the need for clarification regarding hot tubs. Doubtless when the regulations are next reviewed they will be extended to include hot tubs.
