- Joined
- 27 Jan 2008
- Messages
- 29,622
- Reaction score
- 3,658
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
With so many switch mode, or pulse width modulated devices arriving in the domestic situation where the peak current can be far higher than the RMS current is there a rating for rectified load?
It is neither resistive nor inductive, and when we buy switching devices they are rated inductive or resistive but not pulse width modulated or switch mode.
I would consider my freezer and fridge/freezer, and washing machine as using less peak power than in the past due to using inverter motor control. But using rectifiers they tend to be powered from the crest of the wave form rather than even so the peak current is likely much higher than the RMS value.
So in real terms if you have a socket rated at 13A resistive what power can you safely take to supply a freezer? At the moment I supply my old non inverter drive fridge/freezer from a 10A rated thermostat, it keeps my beer to correct brewing temperature. Would that be overloaded if using an inverter drive or not?
With industrial I have turned off the inverter drive before switching supply, but with domestic using items like the lightwave socket referred to in another post you could be switch off while the inverter drive is running. So if rated at 13A resistive what would be the safe power using an inverter drive?
