Hi all,
I'm new here, so please be gentle!
Due to simply being unable to get any response from local trades, I have begun to undertake a downstairs WC renovation.
Despite being modern, all of the pipework in our house is not buried in the walls, so is boxed in. This makes it very difficult to find a modern looking toilet as most are 'back to the wall', but we need a gap to accommodate the boxing. Having found what I thought was one with enough space, its still about 8.5cm out from the wall and I don't want to build the wall out as it will look terrible.
The waste comes up out of the ground, into a 90degree bend, with a very short section of pipe that the pan connector goes into. I can't cut this back far enough to lose the 8.5cm as the pan connector will then be directly into the bend. The section of pipe coming out of the ground has the sink waste coming out of it too, and its all solvent welded together so I can't change anything.
So my question is, can I get away with cutting the bend off at the green line in my photo below, and inserting a flexible pan connector into it? The fins on the flex are 6.5cm, and the distance from the green line to the sink waste is also 6.5cm, so the fins should not impede the flow of water. The concern of course is that if I get this wrong, the pipe goes into the ground, so I need to get it right.
Many thanks in advance for your help!
Tom.
Tom.
