Is it possible to terminate SWA inside this box?
Then use a proper metal box.
Edited to make for easy earthing :lol:
images
If I pretend that the holes are 20 mm (they are in fact 28 mm), then the box won't be waterproof anymore? Sure, the chances of water splashing up into the gap is slim, but that's not the point, right?
You failed to mention that earlier
Eh? I agree that the OP didn't previously mention specific dimensions, but ...
...the problem is these weird rubber bungs that fill the holes in the junction box. If I remove the bung entirely, the hole is too large ....
Kind Regards, John
Kind Regards, John
I apreciate that, john and i read that too, some people expect a thread rather than a 20mm+ hole, not realising the locknut and body just sandwich the box,, 28mm holes are not that common
From the picture I took that to be the case, obviously i was wrong, sorry
images
.. with the caveat that it depends upon the situation. In a few situations, there would be a need/desire to not have a metal box (e.g. if one was wanting to prevent 'exporting of an earth' {via the SWA armour} into an outbuilding which was locally TT'd)
But then you would not want easy earthing. :)
Buy a decent junction box, not the cheap tat with imperial sized holes sold by many places nowadays.
Kind Regards, John
Yes - he wrote that AFTER he'd asked if he could use that box and AFTER HE ALREADY KNEW that the holes were too big for a gland.
:evil:
Yes - he wrote that AFTER he'd asked if he could use that box and AFTER HE ALREADY KNEW that the holes were too big for a gland. :evil:
All very true, but irrelevant to the point I was making (to 333rocky333) - since the OP wrote it BEFORE 333rocky333's post which apparently was written without realisation that the holes were too big.
As for the dig at the OP that you're seemingly trying to have, I assume that (knowing the hole was too big) he was asking whether there was some sort of adapter he could use to install an SWA gland in an oversize hole - and, as you'd probably agree, although such adapters (or various bodges) do exist, it would be far better to use an appropriate box.
Kind Regards, John
Have I missed something? That lid looks like a push fit. If it does not require a tool to remove the lid then likely can't use it anyway.
I hate using plastic so easy for the cable to warp the box so it's not water resistant.
I agree there are times when due to earthing requirements one has to use plastic but put a adaptor to enlarge to 25 or 28 mm and you still have metal not covered with the shroud.
That's a good point, but it may be open to some debate - my experience of things like that is that unless one has fingernails made of cast iron, one usually does need a tool of some sort in order to prise the lid off!
I hate using plastic so easy for the cable to warp the box so it's not water resistant. I agree there are times when due to earthing requirements one has to use plastic but put a adaptor to enlarge to 25 or 28 mm and you still have metal not covered with the shroud.
That's also true. As for 'adaptors', it's obviously posible that just a pair of banjos (or other suitable washer) would be adequate - and one could even use (or improvise) a plastic washer for the outside to eliminate the problem to which you refer - but any such approach would really constitute a 'bodge'. Given that an 'appropriate' box would be so cheap, it would really seem the only sensible way to go.
Kind Regards, John
