Edited to make for easy earthingThen use a proper metal box.![]()
Eh? I agree that the OP didn't previously mention specific dimensions, but ...You failed to mention that earlierIf I pretend that the holes are 20 mm (they are in fact 28 mm), then the box won't be waterproof anymore? Sure, the chances of water splashing up into the gap is slim, but that's not the point, right?
...the problem is these weird rubber bungs that fill the holes in the junction box. If I remove the bung entirely, the hole is too large ....
.. with the caveat that it depends upon the situation. In a few situations, there would be a need/desire to not have a metal box (e.g. if one was wanting to prevent 'exporting of an earth' {via the SWA armour} into an outbuilding which was locally TT'd)Edited to make for easy earthingThen use a proper metal box.![]()
Kind Regards, John
But then you would not want easy earthing... with the caveat that it depends upon the situation. In a few situations, there would be a need/desire to not have a metal box (e.g. if one was wanting to prevent 'exporting of an earth' {via the SWA armour} into an outbuilding which was locally TT'd)Edited to make for easy earthingThen use a proper metal box.![]()
Indeed - which I why I thought that it was a bit of a generalisation (to which there are some exceptions) to give the 'easy earthing' an unqualified massive great green tickBut then you would not want easy earthing.![]()
And nor could I find a way of making yours smaller, without downloading and editingI couldn't find a small tick.![]()
Yes - he wrote that AFTER he'd asked if he could use that box and AFTER HE ALREADY KNEW that the holes were too big for a gland.Eh? I agree that the OP didn't previously mention specific dimensions, but ...
Kind Regards, John
All very true, but irrelevant to the point I was making (to 333rocky333) - since the OP wrote it BEFORE 333rocky333's post which apparently was written without realisation that the holes were too big.Yes - he wrote that AFTER he'd asked if he could use that box and AFTER HE ALREADY KNEW that the holes were too big for a gland.![]()
That's a good point, but it may be open to some debate - my experience of things like that is that unless one has fingernails made of cast iron, one usually does need a tool of some sort in order to prise the lid off!Have I missed something? That lid looks like a push fit. If it does not require a tool to remove the lid then likely can't use it anyway.
That's also true. As for 'adaptors', it's obviously posible that just a pair of banjos (or other suitable washer) would be adequate - and one could even use (or improvise) a plastic washer for the outside to eliminate the problem to which you refer - but any such approach would really constitute a 'bodge'. Given that an 'appropriate' box would be so cheap, it would really seem the only sensible way to go.I hate using plastic so easy for the cable to warp the box so it's not water resistant. I agree there are times when due to earthing requirements one has to use plastic but put a adaptor to enlarge to 25 or 28 mm and you still have metal not covered with the shroud.
