Just make sure emitter size is sufficient to match the heat loss, at reasonably efficient outlet flow temps. Then keep it running when cold outside, with no drastic setbacks.
Hi, I’ve got an ideal Mexico, big thing in the garage , I think there’s a problem with the cylinder at the moment as we are using a lot of water on the meter and our tap water isn’t hot.
I’m wondering whether it’s worth switching to something more efficient rather than repairing what we have?
I’ve heard mixed reviews about both heat pumps and combi s
More information needed. What system is it? Is it pumped CH, gravity HW (on the primary side)? What motorised valves and controls are there?
When it's trying to heat the HW, what happens? Maybe the cylinder stat is faulty.
Why are you thinnking of changing to a combi? There are pros and cons with combis, mostly cons IMO. A heat-only boiler is another option, maybe with improvements to the system (depending on what's there now).
