Hi guys, this is my first post and suspect that possibly like others it's through nescessity, anyway here goes.
Whilst away with my partner we got a call from her daughter saying "we where out of home heating oil" I knew this wasn't the case and upon returning home today confirmed this (near half a tank full) I switched on the heating and hey presto it fired up as usual but after about 15mins it knocked off. Radiators in the house were stone cold but in the outside shed the water pipes running from the boiler to the water pump were hot, the pipes after the water pump were warm but not just as hot. The thermostat on the boiler was set at 65 deg. I yanked up the thermostat and hey presto the burner fired up again, after 5 mins or so it knocked off. At this point there was still no heat in the radiators but the water pipes in the shed before the pump were roasting hot and again a little warmer below but no where near as hot. After turning the heating off at the switch indoors and letting the system cool I fired it up again and felt the water pump (Hmm nearly a big mistake) still pretty warm, there was no slight hum or vibration which I think there should be. Now if the water pump fails would these be signs to expect, I don't want to go buy a new pump if i'm completly wrong. My partner says the heating is in 10yrs. Any help or suggestions would be greatly appreciated.
