Is sulfate damage the same as contaminated hardcore?
27 Dec 2011
Sheffield
i'm looking at buying a property what as had some movement. It was built in 1984 and they was 5 detached property's buit all the same. None of the other property's have had a problem. I've Been told its contaminated hardcore but I can't find info about this on the net only sulfate damage so I was thinking is this the same?
Ive also been told if its sulfate damage the other property's would have it but this is not the case.
Thanks lee.
Contaminated hardcore can be contaminated with lots of things, one of which may be sulphates
The 1984 built property should have a DPM which makes sulphate attack less likely, though not impossible
There may be other reasons for the movement, you need to either get the property surveyed or forget about it
As said sulphate shouldn't be a problem at that build times, but you never know. It needs water (leaking drains, cold supply pipe, plumbing) to start activation which is why neighbours can be OK. A sulphate test cost us £250 and a good fortnight to get result.
Get a structural guy in as sulphate can force out walls making the property unsellable.
