Is the circulating pump to blame?
11 Feb 2008
Dorset
Hi folks, hope you can help.
I've got a Potterton Prima boiler and a Myson CP53 pump. Lately the pump has been making grinding noises but the CH and HW both work fine so I've put off replacing it.
Last night the pump sounded terrible then the boiler started making banging sounds and the cover was too hot to touch. Water also started to come out of the overflow into the garden. Same thing happened this morning when the timer activated the HW.
Is the pump failing causing the boiler to over heat and the expansion tank to overflow?
Any advice gratfully received
pump appears to be in need of replacing, i would also check for bockages around cold feed area
Cheers for the advice.
I was going to take the opportunity to do a drain down and mains flush of both the HW and CH. Can you tell me what's the best way to ensure that the boiler completly empties of water, hopefully preventing an airlock in the process.
Just to remind everyone, it's a Potterton Prima F and it doesn't have any valves or drainage points that I can see.
