After getting some help resolving an oven installation query, from several members of this forum, I thought I would try my luck again.
I have spent a good few hours looking for something, I dont even think exists, there is an obvious workaround, but it would be easier if there was exactly what I needed...
Im after a 13a fused switched connection unit, that will fit a double backbox... at present there is a cooker switched/single socket, which is not being used... courtesy of a recent oven install (which has been discussed on a nother post).
The oven is 13a, and is wired into a socket behind the oven, so I have no single point of local isolation within the kitchen, from which I can turn the power off - other than flicking the switch at the fuse box, and losing the main circuit.
I assumed we oculd simply wire this into the cooker control unit, but this is on its own ciruit and is a 30a, so I need to fuse down via a fused connection unit. I could change the fuse at the source, as its a isolated circuit for the cooker, but the fusebox is a very old dorman smith, so I doubt if i can get any parts for it.
My options are to remove the existing cooker control unit, in favour of a switched fused connection unit, however, these seem to be single sized plates, where the cooker control unit is a double. As we have recently had kitchen done, I would rather find a suitable double, than replace the existing with a single, and have to fill in the gap, which could look quite messy....
This is purely for cosmetic reasons... so does anyone know if a double plate exists, with a switched fused connection unit, and maybe a socket...??
Cheers
Cheers
