Hi - can anyone advise me on this. I am replacing a single undercounter oven with a double oven and an existing gas hob with new one. Under the worksurface is a double outlet 13A socket for the single oven and the gas hob ignition. The new oven is rated at 4.5Kw max so I will need a cooker outlet plate in place of the 13A socket, but can I connect the hob ignition circuit into this as well? I guess the answer is no as the fusing for the hob will then be 30A instead of 13A. Any ideas on how to convert the double 13A socket to somethng more useful - an outlet plate with a 13A single socket perhaps (if it exists)? The existing socket is wired in 6mm T&E to a double pole switch above the worksurface and to a 30A breaker at the consumer unit.
