Ok I'll set the scene so to speak. Do you all recall that noise the pipes make after the toilet has been flushed and is refilling the cistern. Well I get that all the time in my house.
I have no internal leaks to indicate that's where the problem lies. (It’s been a couple of months now and I'm sure I would have noticed an internal leak by now)
When I turn of the supply tap in the kitchen the noise stops.
Also I get better water pressure from the hot tap and that’s just gravity fed from upstairs.
I've no idea where the external stopcock is and am beginning to think the council or contractors have buried in under tarmac by mistake as all the neighbours ones are in front of their houses on the path. I even tried turning next doors stopcock off to see if we were on the same supply which it transpires we are not.
One of the neighbours has suggested that I might have a mains supply leak. There's been no pools of water in the garden but I don't suppose that would be a sure fire sign anyway.
Anyone got any suggestions or should I just ring home serv up and tell them to sort it seeing as I've taken out their insurance.
