Is there a maximum 15 mm pipe length from the 22 mm ring?
17 Feb 2015
Staffordshire
I'm wanting to add 2*1783 watt (6084 BTU) radiators to my existing central heating system. Assuming that the boiler is large enough to accommodate the addition is there a maximum length of 15 mm pipe that can be run from the 22mm ring?
I am planning two individual flow and returns as I doubt that two radiators of this size would work properly off one (correct me if I'm wrong).
The 22 mm ring is on the first floor and the two 15mm flow and return running to the radiators on the ground floor (approximately 9m horizontal and 2.4 vertical for each flow and each return).
Would there be enough pressure in the system or would I have to extend the 22 mm ring?
Thanks for any constructive input
IIChopperII
If you have a 22mm pipe run as a "ring" then this is what is known as a 'one pipe system' and the ring should be extended so that it runs underneath the radiators, so that they sit atop it like this.
The 'T' going directly up from the ring to the radiator will be in 15mm, but it will be very short.
You've not given us any information about the spec of your central heating pump so I'm afraid it's a little difficult to advise whether it's capable of pumping that far or not
Quite apart from telling us if it is a condensing boiler or not!
Apparently some heating aspects are not quite so simple!
Tony
I don't see any evidence of it being likely to be a one pipe!
It's quite simple the OP described it as:
the 22mm ring
A one pipe system is a 'ring' of pipe that flows from the boiler and back to it in a loop as per the diagram I posted. Other systems have separate pipes for flow and return, they are not configured as a ring.
It maybe that the OP has used the wrong terminology, but his post does state that it is a ring.
And he has twice mentioned a flow and return!
Unlikely he is using the correct terms but my bets would be a conventional system!
And he has twice mentioned a flow and return! Unlikely he is using the correct terms but my bets would be a conventional system!
The OP's question is "Is there a maximum 15 mm pipe length from the 22 mm ring?"
He does mention flow and returns, but the post states that he wants to add the "flow and returns" to the "ring". He doesn't say that they are there already. Maybe he has used the wrong term, but 'ring' is hardly a technical word, the OP's question is "Is there a maximum 15 mm pipe length from the 22 mm ring?" Perhaps the OP will confirm what he has, then we can all stop guessing.
Thanks for the reply's and sorry for the wrong use of terminology.
The system is a conventional one with a 22mm flow and return with the 15mm flow and returns 'T'd off this. I've attached a diagram of current and proposed set up.
I think the boiler is a Feroli domicompact F30 B (making it a condensing boiler Agile), and a 30kw output.
muggles I'm unsure of the pump spec, but have attached what I think is a relevant page from the manual.
FYI There is a 12ltr external expansion tank in the set up.
Radiator Extension.pdf
3540B282.pdf
Hope this clears up any ambiguity
IIChopperII
The usual rule of thumb for non condensing boilers was that you could take about 3 kW from 15 mm pipes up to about 3-4 m from the 22 mm.
With a condensing boiler set to a differential of nearly 20C then you could almost double the distance or power.
Tony
Tony
15mm tube will carry a 6kw load @ 10c dt. (0.14 x 4.2 x 10c = 5.8 kW)
15 mm tube @ 20 dt (0.14 x 4.2 x 20c = 11.6 kW)
Tony , had you of recieved the correct training then you wouldn't be making these school boy errors.
