    Dismiss Notice
Is there a time out safety appliance for a kitchen tap?
Discussion in 'Plumbing and Central Heating' started by doggyvonne, 24 Oct 2012.
  1. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    My son with some learning difficulties lives in a 3rd floor flat which has a very slow running hot tap. In order to get enough water hot enough to wash up he has to leave the tap running for five minutes at a time. We own the flat and had a number of plumbers and it isnt the washer and apparently there is nothing manageable which can be done to improve the flow as it is a water pressure problem, but I am wondering if there is a device to put on the tap to make it cut off after 5 minutes as my son does forget the tap is on and at one point he went out and it caused a flood and damage to flat below? Can anyone suggest anything which could be done to the hot tap to make it stop flowing after about five minutes?
  2. Sponsored Links
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    • Thanks Thanks x 1
  4. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    Thanks for the reply. I took a look and they seem to be in China or US and I dont really know which one..if I ask a plumber this question how should I describe the tap..is there a UK recognised name for it? do they sell these things in wickes?
  5. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    My plumber sent this from his phone just now
    'The taps in the link are not designed for use at a kitchen sink they are for use on basins in public toilets ie restaurant's etc (I'm sure you have used them). Also they generally only run for 30-60 seconds them shut down. On a low pressure system such as this I would say the only realistic way of sorting the problem would be to install a pressurised cylinder. A pump would also work however I seem to remember the tank not being big enough. Sorry cant be of more help. I would say the cheapest and easiest way would be for your son to remember to turn it off. Ha!'
    I imagine a pressurised cylinder is a very expensive thing..has anyone any experience of these..my plumber is informative but often chooses the most expensive solution?
  6. OwainDIYer
    OwainDIYer
    5 May 2010
    4,545
    Thanks Received:
    695
    Stirlingshire
    Country:
    self closing taps are standard in public loos, campsite showers etc. Any plumber's merchant should have them, but I can't quickly find mechanical ones with more than about 25 secs delay, so your son would have to hold it on.
    http://www.sheardown.co.uk/Del-Clsg.html
    http://www.eurotaps.co.uk/products.html
    http://www.heatandplumb.com/acatalog/Self_Closing_Taps.html
    Electronically controlled ones probably can have a longer timer, but will be more expensive
    http://www.radacontrols.com/home.htm
    http://www.gentworks.co.uk/Sensor-Taps-c-473/
    • Thanks Thanks x 1
  7. OwainDIYer
    OwainDIYer
    5 May 2010
    4,545
    Thanks Received:
    695
    Stirlingshire
    Country:
    if the problem is the delay in hot water getting from the vented hot water cylinder then a pump will speed that up somewhat. the size of the tank shouldn't be an issue for a kitchen sink tap - it might be if you were using a pumped rainfall shower.
    An alternative is to have a return pipe from the tap to the hot water cylinder and a circulating pump, this means the water in the pipe at the tap is kept hot. it will increase heat losses from the pipes (less heat loss if they're lagged) and use some electricity.
    • Thanks Thanks x 1
  8. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    in his last quote my plumber mentions a pump and says it cant be done in our case..
    from his phone about the electronic taps
    'These type of taps are designed only for modern high pressure systems and once again are more for commercial use rather than domestic dwellings. I would imagine the cost of installing such a tap over a kitchen sink would be very high so prob not affordable anyway.'
  9. calorific
    calorific
    22 Aug 2012
    1,466
    Thanks Received:
    66
    Manchester
    Country:
    Assuming that he has mains cold water supply to the flat at a reasonable pressure, would it not make sense to install an under-sink water heater? This would mean that he wouldn't need 5 minutes worth of hot water due to the increased flow rate and in any case the timed taps already mentioned would then also be an optional backup.
  10. Sponsored Links
  11. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    The flat we bought is about 13 years old and all this has me pondering how a flat was passed by building control with such low pressure..it takes about 10 mins to fill a bowl with suitably hot water for washing up? Are there no regs about water pressure? Unfortunately we were not aware of this when we purchased the flat.
  12. calorific
    calorific
    22 Aug 2012
    1,466
    Thanks Received:
    66
    Manchester
    Country:
    What is the cold water supply like?
    • Thanks Thanks x 1
  13. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
  14. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
  15. calorific
    calorific
    22 Aug 2012
    1,466
    Thanks Received:
    66
    Manchester
    Country:
    OK - I was going along the line of the hot water being gravity fed but the cold water coming directly from the mains. FYI undersink heaters use electricity and so gas would not be required :)
    • Thanks Thanks x 1
  16. doggyvonne
    doggyvonne
    4 Jul 2012
    101
    Thanks Received:
    Devon
    Country:
    That's a good question I will find out..the pressure in the hot bathroom tap is slow too but the over bath shower which heats its own hot water is OK
  17. calorific
    calorific
    22 Aug 2012
    1,466
    Thanks Received:
    66
    Manchester
    Country:
    If the cold water pressure and flow rate is fine, then my previous reply regarding undersink heater is still an option, since these are fed by the cold water mains. It would be entirely possible to run both the kitchen and bathroom hot taps from this same heater and do-away with using the hot water cylinder for anything other than a bath.
    • Thanks Thanks x 1
Loading...
Share This Page
