Hi. I have a scheme whereby the outside sockets (used for gardening tools) will be connected to a cable that will run through the house wall in the direction of a cupboard. Inside the cupboard the idea would be to terminate that cable in a wall plug. So, when I want to use these sockets, I'd use a cable with a plug at one end (to fit into a source of power) and a socket at the other to plug into the plug fitted in the cupboard. The problem is in identifying a suitable plug & socket for the connection inside the cupboard. All the wall-mounted products I've seen are wall sockets, not plugs. I think it would be dangerous to make up a power cable with two plugs on the end. Thanks for your help in this. Richard
