Is there anything wrong with this boiler flue?
Discussion in 'Plumbing and Central Heating' started by OldKettle, 26 Apr 2021.
  1. OldKettle
    OldKettle
    17 Jul 2017
    302
    Thanks Received:
    5
    Country:
    I recently had a boiler service (Ideal combi) and before the engineer left he said that the boiler would not be covered by the warranty, due to a problem with the flue.
    He didn't really give me a good explanation, except to say that "the white pipe should terminate at the wall, rather than come outside".
    I've attached a picture of the flue. Is the engineer right?
    Any thoughts would be much appreciated.
    [​IMG]
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    13,431
    Thanks Received:
    3,104
    Daventry
    Country:
    Yes, he is. Ideal so now permit any of the flue other than the terminal to be on show outside. No white should be visible. The plume kit is also incorrectly installed. Hard to tell from this angle but I suspect a vertical flue would have been a better option here
    • Like Like x 1
  4. CBW
    CBW
    26 Sep 2019
    9,755
    Thanks Received:
    2,673
    North
    Country:
    Is that really clipped into your guttering?
    • Thanks Thanks x 1
  5. ianmcd
    ianmcd
    15 Aug 2010
    24,036
    Thanks Received:
    10,116
    Livingston
    Country:
    Yes he is correct, no white to be on show on Ideal flues, wouldnt go overly worrying over it though, it may invalidate the warranty though
    • Thanks Thanks x 1
  6. OldKettle
    OldKettle
    17 Jul 2017
    302
    Thanks Received:
    5
    Country:
    Thanks for the replies.
    It was installed before I bought the house, but is still under warranty (think it expires in 2023), which I'd like to keep active. I've included a view from inside below.
    I asked the engineer if I just basically needed to get somebody to cut the white pipe to the wall, and he seemed to suggest that was OK (wasn't terribly committal, which is why I am asking here).
    Does that sound right, or would it be better to get it reconfigured?
    Muggles mentions a vertical flue, presumably straight up through the flat roof. I don't want to go to any more expense than needed, but just enough to make sure the warranty is OK.
    [​IMG]
  7. ianmcd
    ianmcd
    15 Aug 2010
    24,036
    Thanks Received:
    10,116
    Livingston
    Country:
    inside is fine, the problem with white showing outside is the plastic might react to UV light, you will find most of us agree it is tatal ******xs but I deal state it so we have to follow, some other manus state it is OK
    • Like Like x 2
    • Thanks Thanks x 1
  8. Sponsored Links
  9. CBW
    CBW
    26 Sep 2019
    9,755
    Thanks Received:
    2,673
    North
    Country:
    It’s not something that you personally can do, as it’s classed as gas work, so needs critical safety checks afterwards. However, you can’t just cut it back anyway, the plume kit would have been used for valid reasons. 2 spring to mind with your set-up:
    1. a vent is above where terminal would finish.
    2. It looks like it’s too close to an internal corner
    • Thanks Thanks x 1
    • Like Like x 1
  10. OldKettle
    OldKettle
    17 Jul 2017
    302
    Thanks Received:
    5
    Country:
    Thanks. I did suspect that it would require somebody gas safe, given the obvious potential for CO leaks.
    For that reason, I'll try not to ask for too many specifics here, but I just wondered if anybody thought that there would possibly be a horizontal flue that would be compliant, or whether a vertical flue would likely have to be installed.
    Also, if UV is the issue, is there anyway that the white part of the pipe could just be boxed. Probably a stupid question but just looking for an easy fix.
  11. CBW
    CBW
    26 Sep 2019
    9,755
    Thanks Received:
    2,673
    North
    Country:
    Vaillant flues can be ran externally, but aren’t obviously compatible and you're not going to be changing the boiler anytime soon. Also there’s that internal corner/neighbouring property.
    A vertical flue might have been the better option, and since boiler is still under warranty, I’d say the flue is still available.
  12. boolie
    boolie
    3 Nov 2020
    365
    Thanks Received:
    14
    Country:
    Isn't that the whole point of GasSafe? I.e. report the installer to gas Safe.. then they will contact him for an explanation and it will be fixed at his expense if he hasn't installed it properly
    Installers details will be in the benchmark section of the manual. If the benchmark isn't filled in your warranty is void anyway
  13. Madrab
    Madrab
    4 Oct 2012
    8,568
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    Ideal do what's called a soffit or balcony flue kit, this allows the centre section of the flue to be extended out beyond the overhang and avoids the build up of POC's under extended soffits/balcony, without extending the white section of the flue.
    Cutting the flue back to the wall under that extended soffit wouldn't be acceptable either IMO, too large an overhang. Would need a good look to see how close to the extension it is too.
    How old is the boiler and what model is it? The way I see it, the engineer missed an opportunity for some remedial work there.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
