Is this a lead water supply pipe?
finally someone gave me a quote. 60 metres total length. the digging area is a gravel path and soil. and then in to the kitchen and up through a concrete floor
£4000 :confused:o_Oo_Oo_O:confused::cautious::sick:
Hire a mini digger and dig it yourself.
i've never done anything like that before.. I own the gravel path however other people also have access to it and other services run underneath. Am nervous about hitting something... would much prefer to get a pro to do it - wasnt expecting this kind of price though
Hire a digger with a driver. The rest is not difficult. Anglian will make the connection free, you just need to lay the pipe, fill in the trench and stick a stoptap on your end.
That quote is For a trench. The moling company are apparently really busy and don't even have time to give me a quote!
Good idea . Will try that route.
this hiring a digger with a driver route sounds like it might be a goer. The guy picked up the phone and is available in a couple of weeks
Just so I know what I'm doing, can you advise on the materials I'll need? So far I've listed the following
  1. 32mm MDPE (minimum 60 metres length)
  2. 32mm mdpe pipe clips
  3. 32mm mdpe pipe inserts
  4. 32mm mdpe stop end (for exposed end of mdpe for water board connection)
  5. 32mm to 15mm stop cock
  6. 110mm soil bend (to go through foundations of house)
  7. 110mm soil pipe
  8. Pipe insulation (for 32mm MDPE)
  9. Sharp sand for covering the pipe in the trench
After I've covered the pipe with sharp sand in the trench, do I just use the soil that was dug out to fill it back up again?
Also, How do I dispose of left over soil? presumably will need a skip?
