- Joined
- 27 Jan 2008
- Messages
- 29,961
- Reaction score
- 3,732
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Thanks.<diagram> .... There's your diode, should not use a three port valve with a type AC RCD I assume, but never seen a warning about it! But think the two port valves also stall the motor, so that does not seem to be a problem, the problem is micro switches sticking.
That's pretty clever [and it subsequently goes on to explain in greater detail]! However, I'm still learning, and, in particular, haven't yet worked out exactly how/why the motor behaves in this way in response to AC/DC.The Honeywell V4073A three port, mid position, spring return valve, is a masterpiece of clever engineering. It manages to move to one of three positions using only a cheap non-reversible AC motor, a spring, a couple of micro-switches, a resistor and a diode, and act as a relay for the boiler into the bargain! However, it has obviously required quite a bit of lateral thinking to conjure up, and its operation is thus not easy to understand. Here's how it works.
..... The spring pulls the valve to open the flow through port B (traditionally connected to the hot water cylinder's heating coil), while the motor winds it towards opening port A (feeding the radiator circuit). If the motor is left continuously powered, it will stall in with port A open, but if it is fed with DC (produced with the resistor and the diode), then it will stall in any position. Two micro-switches, operating just either side of the 'A+B' point, are used to define this position.
That's really just a repeat of what you wrote before(which is something I hadn't previously heard of).
What is the diode meant to achieve, and in what sense is the motor 'stalled' when the diode is in-circuit?
I presume that it would stop working, as would happen with most things designed to run on AC when they were supplied with DC.John - might I suggest you try inserting a diode, in series with a clock motor, and see what happens to the motor?
I now wish I'd left in my inital line in my previous comment. I it seems you have now changed the goal posts and added time control too.So I'm in a room which has been designated to be at Xº because it's Y-o-clock. And for some reason, I don't want it at Xº, because I'm there when I'm not expected to be at Y-o-clock, or I've got a cold and am feeling pathetic and sorry for myself and I want it warmer. Whatever my reasons, in which of the systems you describe above is it easier and therefore better for me to adjust TRVs rather than a control on the wall?
All 3 of these options off a single point of temperature control:...
So I've wandered a tiny bit from DIY territory but returning to a system with multiple rads in a room there are several options if one wishes to adjust the temp on an ad hoc basis, the three most obvious to me as I sit at the keyboard:
Suggests a zone solution EXACTLY what you initially described with no mention of TRVs.Use a motorised valve and space stat to create a zone for the multiple rads.
Is one TRV on each rad, but paired in some way and working together to create a zone.Use intelligent TRVs which can be paired so they act as master/slave to control the others.
Is just one TRV style valve feeding all 3 rads – a system we had in school some 60 years ago on 3" pipes.Use a single TRV (dumb or intelligent) as the zone valve. Afterall said and done it is only a metal thing installed by a wetpants.
Assuming I'm understanding you correctly, I've often wondered why I don't think I've ever seen or heard of anyone doing that.Is just one TRV style valve feeding all 3 rads – a system we had in school some 60 years ago on 3" pipes.Use a single TRV (dumb or intelligent) as the zone valve. Afterall said and done it is only a metal thing installed by a wetpants.
I have noted the manifolds used with under floor heating, and have wondered if the control heads are interchangeable with TRVs. The Kasa TRV head can connect to a remote temperature sensor / thermostat.Assuming I'm understanding you correctly, I've often wondered why I don't think I've ever seen or heard of anyone doing that.
At least 'domestically', I've only ever seen TRVs attached directly to (single) radiators. However, as I think you're suggesting, I see no reason why the very same devices can't be used 'within pipework' in order to control the flow to two or more radiators. Indeed, implementing that is slightly easier today than it was 'way back' - since, as far as I can see, virtually all TRVs these days come with 15mm² compression fittings for both 'in' and 'out'.
That doesn't surprise me but, as I said, I've never seen or heard of it being done in a domestic setting - despite the fact that it would seem to be a fairly obvious thing to do if, as per morqthana's situation, one has two or more radiators in one room.I've seen that done in large open, commercial areas.
Yes, I also did wonder"should not use a three port valve with a type AC RCD I assume"
I`ve not heard that suggested Eric nor had/heard of any problems with it either.
Ditto here and also cannot think of any reason why a valve should have this issue.Yes, I also did wonderAs things are, everything in my house has to be satisfied with Type AC RCDs, and nothing seems to be complaining
Kind Regards, John
Well, I can think of 'the reason' (that when the diode was in circuit, there would be a very large DC component to the current - but I've never heard this being mentioned before (in relation to a 3-port MV) and nor would I lose any sleep over it were it in my houseDitto here and also cannot think of any reason why a valve should have this issue.
Why should that trip a type ac RCD or any RCD?Well, I can think of 'the reason' (that when the diode was in circuit, there would be a very large DC component to the current - but I've never heard this being mentioned before (in relation to a 3-port MV) and nor would I lose any sleep over it were it in my house![]()
