- Joined
- 27 Jan 2008
- Messages
- 27,810
- Reaction score
- 3,369
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
That's fine if you have a wall stat it every room (but then you wouldn't need TRVs, anyway!).
I have repeated many times, the problem is finding out what product will do what, and keeping up with the changes. So 5 years ago when I moved in here, Hive would not work with OpenTherm, and Tado had also removed their OpenTherm versions from the UK market, and Nest would work with Energenie, all this has changed, Tapo and Kasa now both use same hub and the TP-Link products seem to be taking the market by storm. I keep mixing up Tapo (TP-Link) with Tado which is a completely different make.
There are two very different ways to control a boiler, one is electric, the other is with the return water, many uses both, and in both cases they can control the boiler in an analogue manner, which is better, or a digital manner (on/off) commonly referred to as mark/space. With my boiler it can only work with mark/space, but modern boilers using mark/space makes them inefficient, as every time a wall thermostat turns the boiler off, it has to start again from scratch setting how much to modulate to gain the latent heat from the flue gases.
The homes have improved heat loss wise, and I know turning my heating down overnight it is very rare the boiler will ever fire, so turning the boiler completely off with a programmer will likely have in the main same result as turning it down with a programmable thermostat.
Turning the heating up again, I found not so simple, before fitting Wiser, I used a Nest Gen 3 thermostat, it could only go in the hall, as that was where the wires to power it went, turn from 16°C to 20°C and the heating would likely run for an hour, and over shoot, so I set it to advance in 0.5°C steps, around once every hour, this resulted in it taking 8 hours to reach 20°C so would hit it at around 4:30 pm, but same result could have been done with a simple time switch. In fact, likely better. As it depended how much the hall had cooled overnight as to when the heating turned on in the morning, it was a useless thermostat, at least for my home, I can see why wiring did not go into living room, the living room has an open fire, The only option is to have multi-thermostats able to turn on the boiler, which I now have.
But we all seem to be looking for a one system to suit all, and although Wiser may be flexable enough to do that, it's expensive, and there are home where one thermostat is enough. This
