looking through manual look like it is not suitable,
need to fit fire tommorrow so need to tell customer if he needs to replace pot
Any chimney pot used shall have no dimension across the axis of its outlet, or outlets, less than 175 mm. There are in existence many types of chimney pots...In cases where an installation is being carried out in an existing property the installer may be unable to gain easy access to the chimney stack to check outlet opening sizes. In such cases Figure 4 will enable the installer to identify some of those terminations which are... very likely to be unsuitable [i.e. chimney pots as shown in Figure 4(a)] and which should be removed or investigated further.
