Is this likely to be load bearing.
10 Nov 2009
Yorkshire
Hi and thanks in advance
This is in my bathroom, above the stud wall is a 7 inch ceiling joist it runs external wall to external wall, where the small stud ladder is, that is to square the room off as that back wall is the chimney, I'm having a new bathroom suite fitted and the plumber has suggested running the sink waste 32mm through the wall studs, the studs are 3x2, this worries me slightly, if its not load bearing the studs still have to carry the plasterboard and the tiles.
After drilling the holes through the studs, why not strengthen the partition by screwing either 12mm ply or 11 OSB to the studwork before applying the plasterboard (making sure of course that the screws don't go in near the pipework).
I'm really not sure about him drilling the holes in the first place, it will be 12mm moisture board going over the top, would the whole wall need boarding with wbp or osb?
Yes, once the pipework is in, overboard the whole wall with ply/OSB from floor to ceiling before applying your finish. This will strengthen it and compensate for the studs being thinner where they are drilled.
