Is this normal
25 Oct 2016
Installed texecom 48 seem to be understanding it now (programme etc)but it seems a bit slow for example if I press the PA button may be a second or two before sounders start any other alarm I’ve had it’s instant thanks
I think you would find that the delay is meant to be there, so there is no interference between the two actions. The sounders going off then has no chance of upsetting any signalling that may be connected and the PA.
After all the PA is more important than the sounders, especially if it has been operated in good faith, most aren't. They are meant for use as a result of physical violence, NOT for a shoplifter, house broken into, someone swearing at you or similar.
