Evening all,
I've recently had the gas fire capped and decided to make a start on opening up the original fireplace (stone build property late 1800s) in preparation for a wood burner. Once the mantel and tiles were removed I was surprised at the size of the opening, and even more so the size of the stone lintel.
As you can see from the picture the lintel is slightly off centre with less end bearing on the right. Does this look supported enough before I start taking out the bricks inside the opening that were built up for the gas fire? Am I right in thinking it should be a minimum of 150mm on each side, and does this differ depending on lintel construction?
Cheers
Cheers
