I need help and advice with my house water system. I have a three storey house, your standard 1930's bay fronted semi-detached with a loft conversion. We have a bathroom with showers on the middle and top floors and an additional toilet on the ground floor. We have gas CH served by an Alpha CD20S system boiler coupled to a 200l MegaFLow tank on the middle floor. We now basically have four adults living in the house (my kids have grown up!), and it has reached the stage where we need to make an appointment to have an uninterrupted shower! We can run one shower very well, both are mixer showers, but as soon as anyone else runs a tap or flushes a toilet you know the result. Much dancing in the shower! Pressure at the outside tap near the stop cock measures 2.7bar static and and 1.6 dynamic (whenever I have measured it), and flow can be measured in the top shower at 10 l/m when it's running well. However, it can be practically zero when it's not or anywhere in between causing temporpary disruptions. When we had the loft converted (circa 2008) I asked the plumber to fit the best solution that would provide a good shower in the loft, hence the system boiler and Megaflow according to him, but the problem appears to be lack of cold water pressure or flow or both.
I've looked into this a bit and your standard Salamandar pressure booster doesn't look like it's going to help me. I found the Powertank water boosting system on line so I rang the company and they say it will be ideal (they would of course). It's not cheap by any stretch but I am prepared to pay the cost if it sorts out our problem. We would like to at least run one shower without fear of it being interrupted by running taps or flushing toilets. That would be fantastic.
Can you let me know what you think? Would a pressure booster set be the solution? If not any advice welcome.
Cheers.
Cheers.
