Is top entry by SWA CW into Masterseal acceptable?
Bottom drain hole drilled. Bottom/side exit also in SWA. North facing wall, outside, end of a long cable run. Piranha obviously re plastic enclosure.
Yes an SWA gland is IP68, but as far as I know it is a no-no because a) shroud is not waterproof and b) water will accumulate in the gland seal. It is certainly not Best Practice even if the regs (do) appear to permit it.
Thus it needs to be redone if at all practicable?
