Is wood burning in the garden legal in UK?
If more harmful is the criteria for being illegal, then exhaust fumes from the motor cars are definitely million and billion times more harmful than smoke from all the wood burners in the whole world.
A wood burner is to a gas boiler what a horse and buggy is to a car, ie outdated, pointless and expensive [a "lifestyle choice", in other words].
More particulate matter emissions from vehicles comes from brake, road and tyre wear than from fuel combustion.
What about all the passenger jet planes taking off every minute in the aiports? They must be burning billions of times of fuel than anything in the world polluting the universe with much effect. Why not ban them all, and make them illegal?
I spent 24h at Manchester airport due to a delayed flight recently, and the places stinks. There is no fresh air to be had anywhere. But I don't notice that when planes fly over my house, because they're far away and the pollution is dispersed. That's what I'm complaining about, really. When my neighbours use their wood burners, it stinks.
They are all part of the serious pollution which are much more in amount and harmful to human health than wood burning smell.
When you are in your house cooking, some of your neighbors might smell the food you are cooking, and they might not like it. But they don't complain about it because it is just what living in community means and entails.
I was around 2008 asked to make a web page saying how bad wood burners are for the environment, I felt step one was some research, and he was correct for some wood burners, the problem lies in particular emissions, it seems if the fire is not hot enough, then it can send out these particular emissions, and only real way to stop them is add air after the first burn to ensure all fuel is used.
This produced a second problem, the fire needs to burn at a set rate, too high and heat going out of the flue, too low and one gets the particular emissions. So a series of wood burners have been designed to fully burn the wood, but as part of it there is a need to store the heat, so you can burn at set rate, but not all the heat is released at that time.
The DIY model rocket-mass-heater-diagram.pngis built with a rock or concrete seat which stores the heat, note near horizontal flue, as it is condensing so water needs to be able to run out, look up rocket wood burner to learn more, not sure what insurance companies would say? Another condensing wood burner here Hughes Condensing Stove 2 small.jpgI looked at it and emailed to find out what safety system there is for a power cut, as it clearly relies on having power to it. I got no answer. But some are not so complex this one wallnoefer.PNGdoes again rely on electric, but it would seem one could at least rake out the fire, and today with solar power and the battery which goes with it I do have an UPS supply. (uninterruptible power supply)
The main idea however is hinged around storing the heat, I have seen one house with this sort of setup, Torrent pipe example.PNG due to wanting not to rely on electric power, the water tanks were on the first floor, they were around 100 gallon each, and it worked well, my brother-in-law could visit his daughters in Germany and on return in the airport set the heating higher again, and the solar was enough to keep his house warm while away to stop freezing, and able to reheat the house for his return.
When at home a fire in the evening was enough to keep home warm all day, it would be lit and allowed to burn out. And the system allowed him to use electric or LPG if he did not want to light a fire, all heating the same set of radiators, it was an A1 system.
However when he moved, and looked in to having same system in new home, he was told the cost of building the floor to take the weight of 200 gallons of water, etc. It would cost around the £25k mark to install it. And that's the problem.
The clean air act it seems is not nation wide, it depends where you live as to if a smokeless zone or not, and it does need some one to complain. I do have an open fire, and I have got wood I can burn, but I have never to date lit a fire, it is for emergency only. As to if I need emergency heating not sure, it would depend on when we got a power cut, my solar panels and battery if the power cut happens when batteries fully charged would likely last forever, unless we got a few dark days, but if it was to fail at midnight with only 10% battery left, then unlikely it would last the night.
So the grate remains, for the emergency. But there is a huge difference with emergency use, to daily use. And if the neighbours complain I can see how some one using an emergency fire daily could get stopped. I have not seen a home in years where open fires are their only heating, B&Q and the likes use to sell cheap emergency fires, but not seen them for a very long time. I can't see any council official stopping one using solid fuel fires during a power cut.
However I remember around 1966 going to Warrington on my scooter with my mum and dad in their car, and around the river Weaver I had to guide my dad as he could not see the curb, I have not seen smog like that for many years, but with the price of oil, gas, and electric raising I can see people trying to save money by burning wood. Unless you know what the wood is that can be dangerous, cut in the wood pile, could you identify lilac, which if burn is deadly poison.
In part of my career, I installed and commission big commercial incinerators. Some of which, included an after-burner, a compartment, in the outlet, which had it's own gas burners. Some were 'zero-fuel', gas to get them going, but once well lit, there burned clean with no extra fuel.
Not every wood burning stoves are smoky. I have a smokless fire pit, and it burns really smokless clean. It has tripple burning chambers which reburns the trapped smokes in the burner, which makes burning clean and very efficient. Provided that the woods and logs are well dried and seasoned, and the stove is well designed, and the operator knows what he is doing in wood burning, wood burning can be cleaner and economic efficient energy source than any others.
That sounds great. Do you use it just for burning wood or do you use it to heat something?
We use it to heat space of the patio to sit around at cold nights, but sometimes boil the water to make coffees and teas, and on some occasions also do BBQ placing the grill on the fire.
I also have a wood burning stove in the shed with the 2ndary burning chamber design. It also burns very clean with almost no smoke when fed with dried and seasoned logs.
I normally use a repurposed washing machine/drier drum. They are perfect for the job, lots of holes to let air in, for a hotter, cleaner burn. My last one turned out to be galvanised steel, the galv burns away, then the rust quickly - so I'm presently seeking a replacement, but stainless steel. You just make up three legs for it, and bolt them in place.
A few years ago, an entire large dead tree came down. I offered it on FB, for anyone with a wood stove, to come along cut it up, and take it, but no takers. I ended up buying a petrol chainsaw, cutting it up myself, and burning myself, at the back of the back garden.
