Isolating Push Fit Pipes to Tap's in Kitchen
23 Jun 2014
Staffordshire
Hi all, never used push fit before so not entirely sure how they work.
Since moving into the house ive noticed that Hot/Cold differ across our taps and want to get them all the same, most have a brass compression valve with isolator on so straight forward.....but in the kitchen they are connected by push fit connectors with no isolation valve.
Is this going to make the task much more difficult? Cold water is mains, hot water is cylinder.
Cold tap to kitchen will be mains, so turning off stop cock will turn off feed to tap
If you have a vented hot water cylinder, the hot water comes out the top of the cylinder is pushed out by pressure from cold water from tank in loft, if you have an isolation valve going into hot water tank turn that off. If not turn off cold water mains and run cold taps upstairs until cold tank emptied
obviously open kitchen taps before disconnecting
If you have unvented cylinder, somebody else will need to say how’s its done, I know nothing about them
Thanks, I thought that may be the case! And I assume you mean run hot taps/hot tank? :LOL:
Turn off the cold supply to the cylinder.
Open hot tap(s), some water will flow out under pressure until the expansion vessel is empty.
