Hello. I have got to fit mono-bloc flexi’s to a 15mm pipe. It seems that a flat faced isolation valve will do the trick:
1) in a review someone voiced a concern that if it was not ‘full bore’ it would restrict water flow. Is this true and if so, is there such a thing as a full- bore flat faced isolation valve?
2) the end of the flexi is female, approx 20mm ID. Does this mean that I need a 1/2” BSP valve?
thank you!
thank you!
