Just moved in to a new build. All the pipe work has been done in plastic pipes, all the taps in the house except the kitchen taps have no isolation valves installed and there is no way to directly isolate just a single tap. I want to replace bath taps with a mixer. Problem is that there is no isolation valves on any tap. I have the main water stop cock valve under the kitchen sink. However, the hot water runs from a tank which is heated through a solar hot water system. So turning off the main stop cock valve i'm assuming will only turn off the cold water. So question is how would I turn of the cold water as the tank may contain existing hot water already in it?
