Isolation valves for heating
6 Feb 2010
Blackpool
Are the hep2o isolation valves ok installed on C/H. I no the cheap brass ones leak from the o-rings after time. Thanks
What does it say in the instructions or their website? Maybe rather than buy cheap brass, get decent ones?
ISO valves designed for (edit) hot and cold water aren't normally a standard for use in CH systems and TBH there isn't really any instance where ISO valves should be used. Where valves are needed then one specifically designed to be used in CH systems would normally be used.
