Isolation Valves on Bath Taps - Yay or Nay ???
24 Jan 2012
South Glamorgan
Hello all
I've recently been working on site and noticed some propertys have isolation valves attached to the bath taps and some not? Is this right or wrong?
Jibbs
No just something else to leak. If the isolation valves are available outside the bath then fine.
Good practice to fit them as long as you use good quality ones. Saves wastage of water when it comes to maintenance. I like yo use the ones with flow restrictors built in so that you can balance the water supplies throughout the property.
Isn't fitting local isolation valve a water reg requirement now, at least for new build.
