Issue with installing Drayton Wiser smart thermostat
7 Mar 2019
Hi
Looking for some help please. Just purchased a Drayton Wiser smart thermostat and some smart TRVs because they said easy to install - that was my first mistake.
Unfortunately, its proving not to be, mainly because of my current setup. I have a Worcester CD30 classic regular boiler with a Honeywell HC60NG wireless relay and HCW80 thermostat. I also have a Randall Drayton KS715 programmable timer.
My understanding is that if I didn't have the HC60NG in the setup I could simply remove the programmable timer and install the Wiser on the same universal back plate in place of the programmable timer ( after checking the wiring first on the back plate)
My issue is. I need to remove the HC60NG from the system. How do I do that please? Do I need to get wiring that was plugged into the HC60NG to the Wiser from the boiler?
The Wiser is a 2-channel device as I have 1 channel for heating and one for hot water.
Can some one please help. My friendly electrician ran away
To get some help you probably need to post some pictures from the backplate of your current relay. They are not the same as for Wiser, so you would have to rewire it.
