- Joined
- 6 Jan 2026
- Messages
- 7
- Reaction score
- 0
- Country
Firstly, I've done ALOT of reading on this subject already so I come to this with some knowledge, however, as I think many of you who are reading this for answers have also experienced, there are many different opinions on the best way to install.
Our setup is a unfilled cavity (approx 50 - 60mm) which I'm planning to stud directly onto the internal skin and fix the Celotex PL4060 (insulated pb) on top creating a void behind for electrical and plumbing. Part of this is for a bedroom, but some will form a wall in an en suite.
In addition, the room in question is partially in the roof i.e. the top half of the walls are sloped so at the join between the wall and the celiing I plan to use XR4000 (100 - 150mm) in the rafters (leaving a 50mm air gap around the roof edge and top up the attic with rockwool to a depth of 300mm (this is preferred to PIR as it gives more flexibility for installing downlights). For the gable wall I will use the PL4060 up to the rafters/ceiling. I then will tape up all the joins in the PL4060 and the XR4000 and the rafters to create a complete vapour barrier. Whether I get to new build R values of 0.3 I'm not sure but I'm certainly expecting a much more thermally stable room.
So, my questions;
1. I understand studding is much preferred to dot dab to reduce condensation issues (also my preference to allow for services) but I have read mixed opinion on whether the stud work can be attached directly to the skin or not, some saying it needs a 50mm air gap behind. I'd prefer to not lose internal space but equally want it done right.
2. In addition to the PL4060, were have been considering to have EPS beads blown into the cavity. We like this option as it gives the additional benefit to the rooms on the ground floor which we are currently not in a position to rennovate and want to have improved thermal performance. Can you use these 2 products together, and if so does that change where you can put the stud work?
3. If the stud work is attached to the wall, do you need to add an vapour control to the contact point with the wall or will the VPL internally mean the warm air is unlikely to get through?
Sorry for the long post, alot of variables so thought better to over share to try and get the best information possible.
Thanks to anyone who can help.
Cheers,
Tim
So, my questions;
Cheers,
Tim
