JG speedfit stop end question
5 Oct 2014
Hertfordshire
I'm planning ahead for a project where I am going to need to use some JG speedfit stop ends on some plastic pipe.
I've bought a bag of the super-seal pipe inserts but I've noticed that they are labelled 'twist lock' while the stop end is 'standard connection'.
I presume that they are compatible as there didn't seem to be another option, but I just wanted some reassurance and to understand why they are labelled like that.
Thank you
The super seal are designed to work with the twist lock fittings. They'll work with stop ends but technically should just be non superseal.
No. You can cut off the insert a bit just behind the o ring on top, it then just becomes a normal insert.
Unless the pipe is speedfit, the susperseals are a PITA to insert and usually get destroyed when trying to remove them... Even if the pipe is JG, it's still a pain.
Make sure you use plenty of silicone spray on them.
Sorry to reopen this question, but I popped back to Wickes to get a pack of the normal non super-seal inserts and they were also labelled twist lock! They also seem to have a little nick out of the edge which looks like it might be part of the twist lock system.
Slightly confused!
