Joining 90 degrees solid wood kitchen worktop
22 Jan 2010
Sussex
Hello guys,
I'm about to finished building my kitchen, the work tops I've got are solid wood. They are square edged worktops all the way round. I assumed I would need a mitre joint that goes up and then across
Like this
However I've been told to but them up to each other and buscuit them.
Is this the right way about it?
Thanks in advance
J[/img]
Mitring is used to deal with joining a bullnosed or chamfered edge.
If your tops are square edged then you can butt them.
But if there is a tiny chamfer on the front edge, then butting them will leave a gap or a groove, so you will probably need to mitre them
