    Dismiss Notice
JOINING MDF
Discussion in 'Wood / Woodwork / Carpentry' started by jersey, 20 May 2008.
  1. jersey
    jersey
    29 Jan 2008
    61
    Thanks Received:
    Derby
    Country:
    building a book shelf 2.6m high so i need to join 2 pieces of mdf together will it be strong enough if i glue & dowel them? or do i need to get some kind of bracket made (didn,t mention it,s only 20" wide & 14" deep ) hope this makes sense any ideas
  2. big-all
    big-all
    12 Jul 2004
    18,670
    Thanks Received:
    1,453
    Surrey
    Country:
    several options realy
    if its a boring basic bookshelve then plan the bookshelve as two halves with the bottom complete finnishing with a shelve as the top but inside the sides
    in otherwords you cut all 10 or however many shelves the same length and line the top shelve with the top sides
    assuming they are 12 or 18mm you can dowel or slot biscuit being carfull if you used screws at the join to avoid them
    other choices are to build a fancy plinth of 2 or 3 layers and a pelmit again of 2 or 3 layers to take up the difference between 2440 and 2600
    dont forget iff the full ceilling heigh is 2600your shelves will have to be at least 50mm smaller to allow the unit to stand up from the horizontal because of the diagonal being greater than the length
    or if in 2 pieces with dowels or biscuits you will need halve the dowel length clearence plus a few mm to alow you to drop the top on the bottom
  3. Sponsored Links
  4. Jasonb
    Jasonb
    20 Aug 2004
    2,420
    Thanks Received:
    94
    Surrey
    Country:
    Easiest option is to go to a decent panel supplier and by a large press sheet this will be 3050x1220.
    If you already have the boards then as BA says dowels or biscuits will keep the two halfs in line and there is no pulling loads. Fill any gaps with epoxy wood filler, sand and paint.
    Jason
  5. jersey
    jersey
    29 Jan 2008
    61
    Thanks Received:
    Derby
    Country:
    cheers ba & jason all very helpful think ill dowel and glue once again cheers
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
