Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
You can simply use long screws, drill holes to fit diameter of screw head about 50-100mm deep ( depending on timber dimensions) then join with long screws.
High Tensile ideal for landscaping and decking. Countersunk head no pilot hole needed. Driver bit in box Heavy duty screw ideal for landscaping and decking• Countersunk head allows fascia board fixing and minimal timber damage• No pilot hole needed in most applications• Driver bit in box• The...
www.toolstation.com
The photos don’t show how the chairs are assembled, so they may not be attached as you thought.
