Joining Vents
20 Jan 2008
Hi there
Hob vents by passing through main wall, turning "up" 18cm - and exits to a weatherproof vent chimney on the small flat roof adjacent
"Outside" under the flat roof is a tumble dryer ... which is venting through an external doorway.The Tumble is right under access to the hob vent exit ... surely a convenient fit
Understand that you don't want cooking smells in the dryer tube or lint in the hob tube ... but they both will exit very quickly ( just 18cm before exit to outside
Can I simply combine the two?
Should there be some form of baffle between them?
Is there such a thing as a 2 vents in/1 vent out connector (haven't seen one)?
Ta muchly !
Thank You , Spark.
Is your answer based on danger of fire ( Tumbles are renouned, as we know) with the possibility of one tube feeding the other?
Or just because it sounds like a daft thing to do?
With only one vent chimney punched through the roof - the convenience is very tempting.
cheers
Not really thinking of fire tho that should be considered, it was based on if only one was running then the air could be forced back through the other.
you could put backdraft shutters into each pipe.should eliminate the problem spark just mentioned.still no substitutefor two separate pipes though.
is there a chance the moisture from the tumble could make it way into the fan?
if so this is dangerous
also,will the moisture and air from the tumble rise upwards?
if it does you need a condensation trap or the the moisture will run straight back down the tube and into the tumble
Spark - agreed, it could blow into the other
Daytona
Backdraught shutters - that did occur to me, just to keep some degree of seperation.
I also thought of getting to the back of the chimney and completely halving it's void with a baffle. Then, in theory, the exits are , essentially, seperate - if a little constricted.
Didn't think of moisture rteturn ... good point.
Thanks, Gents, for thoughts.
This issue has to happen in so many kitchen/utility room enviroments, don't it? With some access points being quite tricky ... and the expense of hacking through cavity walls etc --- using the one exit would often be logical.
My thought would be to 'bundle' together two pieces of rectangular duct to make a 2 compartment 'square' duct passing through one hole, but serving both appliances and keeping the flows completely seperate.
At the top, you could turn the two ducts 90 or 180 degrees in opposite diredtions.
