- Joined
- 20 Jan 2008
- Messages
- 16
- Reaction score
- 0
- Country
Hi there
Hob vents by passing through main wall, turning "up" 18cm - and exits to a weatherproof vent chimney on the small flat roof adjacent
"Outside" under the flat roof is a tumble dryer ... which is venting through an external doorway.The Tumble is right under access to the hob vent exit ... surely a convenient fit
Understand that you don't want cooking smells in the dryer tube or lint in the hob tube ... but they both will exit very quickly ( just 18cm before exit to outside
Can I simply combine the two?
Should there be some form of baffle between them?
Is there such a thing as a 2 vents in/1 vent out connector (haven't seen one)?
Ta muchly !
Ta muchly !
