In order to join a Zinc plated bolt to an ABS plastic hole (tapping the hole is not an option), is Gorilla Glue suitable, or is anybody able to suggest something else that'll work.
You aren't going to get the best sort of fixing here and personally I'd consider using hot glue......polythene sticks well to ABS.
presumably you can't get a nut on the underside of the material?
John
